Wire caught on fire.
KennyV
... only reason I went to the idea of a bad switch was the fact it occurred on shutoff when there should have not current going through that wire.
That was my first thought also... but with a resistive heating spot, it could have generated a lot of heat, razing the temperature past the plastic flash point. then with the engine shut off and the air movement around it stopped, all that heat would have lit the plastic.
It looks like there is a dab of yellow plastic on top, that would have been a 20 amp fuse, if that is correct, he could cut out the old fuse holder, and splice in a new one with a fuse, should be less than $5 repair... :smile:KennyV
I guess we'll have to wait for a couple more pics of that part. Can't remember, but isn't yellow a 30 amp fuse? Most craftsman use 30 amps in their systems.
KennyV
Now that you mention it, I'd better look on chart to be sure... Yellow 20 , Green 30...
Some of the colors are not that pronounced .. especially after a flame has played with it.
Hope he places a few more pictures. :smile:KennyV
I was better with colors 60 years ago! Thanks.
KennyV
Ha ... 60 years ago, I was 7 .... and I think that may have been around the time I peaked in colors & coloring... :smile:KennyV
Combining colors and numbers has always been hard for me. That's why I got the Amperage wrong.
