Wire caught on fire.
Melly26
Hi guys, newbie here. I bought a Craftsman riding mower today on Craigslist. It ran fine and no problems when I checked it out. But once I brought it home and gave it another run and then turned off the mower, a spark occurred in the wiring then proceeded to catch on fire. I know nothing about mowers and was wondering what caused it, how it can be fixed, and how much cost would be involved. Thanks!
KennyV
WELCOME to LMF...
You are going to have to tell more about that wire.
It is obvious that it had an over current failure. If you do not know what wire it is, click some pictures of it & post them. It will be relatively easy to speculate as to what caused the problem... especially if you identify what wire shorted out. (and it likely shorted to the frame or sheet metal on the mower... :smile:KennyV
Melly26
I apologize for not including photos. Here they are :)
Looking at your photos, I can give you a guess as to the cause, but remember it is only a guess as I cannot see everything I would like to. My guess is that your key switch shorted out. From your pics, to me it is the fuse holder which burned up. For it to burn up like that you would have had to have a direct short to ground somewhere. Not being there to see other things makes it very difficult to give a better diagnosis of the cause. KennyV may have some other ideas. I am trying to find a wiring diagram to give you some other things to check.
Melly26
If more photos are needed, just let me know. I am not sure if this would be relevant to the cause, but I noticed that one of the bulbs in the front didn't work when I turned them on.
Going to wait for KennyV to check in and see what he has to say, before I do anymore guessing.
KennyV
Looking at the pictures, Was it a wire that burned or just that black plastic block?
I can't make out what the symbol is on the side of it is, angle is a little too steep.
But like Rivets said,it looks like a fuse holder that is burnt up. If that is what that component was... I would also suggest that corrosion on the fuse spade & fuse holder generated enough heat to melt and destroy the fuse and holder. If this is the case you may not necessarily have a short, normal current flow through a resistance, like corrosion, will generate a Lot of heat.
Can you give a better picture or 2 of that burnt plastic block? :smile:KennyV
If no other wires are damaged, I would second the corroded fuse spade causing excessive heat.
You both may be right, the only reason I went to the idea of a bad switch was the fact it occurred on shutoff when there should have not current going through that wire.
