Apollos7
I got it! First pull; it runs great. I think it was the bowl mounting screw. I’ve cleaned several times, but this time I ran a torch cleaning tool through it. Even though I soaked it in parts cleaner and sprayed it and blew it out before, I still got some dirt out of it. I also suspected the o-ring around the intake tube. The plate that the carburetor bolts to is pretty flimsy. I clamped a pair of vice grips on the flange where it is thinnest on top while I tightened down the mount bolts. Thanks everyone for your help!
