Apollos7
- May 17, 2021
- Threads
- 2
- 13
Hello,
I’ve searched, but haven’t found a similar problem to what I’m having. I picked up a Craftsman Easy Start 917.378890 with a B&S 6.25 hp: these are the numbers I found on it 123K05-0344-E1. It didn’t run, so this is what I’ve done. Cleaned gas tank, new plug and air filter, cleaned carb and installed repair kit. I put the coil on an ohm meter, but the numbers were all over the place. The guy at the local parts shop did a bench test. He said it had good spark, and suggested no replacing it. Currently, it will start right up, and run a couple of seconds. After about 10 times, it will keep running, and slowly climb until it runs smooth and steady. It operates great and will start right back up , as long as it’s warm. The compression is around 60 psi, if that means anything on these. I put a little oil in the cylinder, but the compression didn’t go up any. I’ve removed the head, decarbed, and checked valve movement. It all looks pretty good. The gasket is in good shape. The valves seam to be tight ( they don’t turn when seated). All that seams to be left is that coil, but it doesn’t make sense to me. Can anyone make sense of this? Thanks!
P.S. I addressed that primer issue with a washer bolted down over that flimsy plastic housing.
