bullet bob
- Nov 14, 2019
- 26
- 204
Thanks, and my neighbor thanks you too.The zirks or 1/4" bolts we are referring to here are on the very front of the frame, one on each side, the vertical part that houses the front caster bearings. If there are 1/4" bolts there (takes a 7/16 socket to remove)...simply remove the bolts and screw in grease zirks and grease during routine maintenance.
