Safety, of course.. On a push mower (for example) if you bumped the cutting blade, it could start up & possibly chop off yer arm..
I think this is left over from years gone by, when engines had true mags. I had an old Wisconsin 7 hp that had a mag, and you could turn the flywheel by hand and you would hear a click. That click was a full power spark, so it was possible to bump start this engine.
That would be a manly bump. Has anyone ever seen/heard of this happening?
I agree I have never seen or heard of anything happening. I am sure going to disconnect the plug if I am handling the blade under a push mower for what little time it takes. Do what you like because if by chance something did happen when you are working on it I wouldn't feel a thing or even know about it. We all have a different idea on safety and its not fun sitting in a ER.
Never had one actually start but every now & then one will fire if it has a combustable mix in the chamber.
for the same reason I generally pull the plug most of time I will be pulling it out in any case and even a back spin off compression can nip the tip of a finger
