Why disconnect spark plug when servicing?
jm123
I've seen this recommended in a number of places. Wondering why.
7394
Safety, of course.. On a push mower (for example) if you bumped the cutting blade, it could start up & possibly chop off yer arm..
jm123
That would be a manly bump. Has anyone ever seen/heard of this happening?
I think this is left over from years gone by, when engines had true mags. I had an old Wisconsin 7 hp that had a mag, and you could turn the flywheel by hand and you would hear a click. That click was a full power spark, so it was possible to bump start this engine.
jm123
Thanks.
reynoldston
I agree I have never seen or heard of anything happening. I am sure going to disconnect the plug if I am handling the blade under a push mower for what little time it takes. Do what you like because if by chance something did happen when you are working on it I wouldn't feel a thing or even know about it. We all have a different idea on safety and its not fun sitting in a ER.
jm123
I agree. Having good medical insurance doesn't mean that I want to use it. Just trying to understand *why* it is recommended. Old wives tale? Ladder warning sticker syndrome?
Never had one actually start but every now & then one will fire if it has a combustable mix in the chamber.
for the same reason I generally pull the plug most of time I will be pulling it out in any case and even a back spin off compression can nip the tip of a finger
jm123
Thanks.
reynoldston
Another habit I have is disconnecting the battery cable on a rider before working on them. A wrench in the wrong place makes for sparks.
