bullet bob
- Nov 14, 2019
- 21
- 156
Guys, I've got 2 types of aerators. One is the spikes which I used to pull behind me practically each time I mowed. Don't know if it helps, but the grass looked nice. Then I graduated to the plug type. I use this maybe once a year. So I've got several questions for you pros. Does my spike guy do anything? I run it with several concrete blocks on it. Does it hurt/do anything to attach it each time I mow? And the plug type, when should I be using it? And how often? Live in Ohio, USA. Homeowner. Thanks all.
