kbowley
- Jun 8, 2011
- 2
- 225
The issue with the electric mowers is if they fail, who is going to fix it? The two most common issues are battery and motor failure. The motors will overheat in heavy, thick grass and melt the windings. Good luck getting a new motor. However, no need to worry about gas and oil. Just the blade and put a little grease on the self-propelled gear on each wheel once a year. just a little bit. You must get parts from Ego as they are proprietary. You should be fine. just don't try to mow very thick, tall grass on a sweltering day.
