Nice catch on the tin air ducting shields MParr. Spot on as usual sir.Nothing has fallen out next to the starter motor. The blower cover and shielding isn’t positioned correctly.
Take the blower cover off and clean everything good. Check all of the wiring connections.Put the blower cover back on. Pay close attention to the tin shields on the side of the engine. The tin shield next to the starter is out of place. It should be tucked into the blower shield. Those blue wires should be in the slot of the tin shield.
You either have a fuel or electrical problem.
Is the oil level correct?
Just got a mouse nest out of one today. I hate meices to pieces. Cleaned lots of them out of engines.Have you ever, removed the top engine cover and looked at the block cooling fins for grass, oil, grit, mice and their nests and the like? Did you know that one scalping session can clog said fins and cause overheats? Did you know this is in your engine manual as a yearly item as in a MUST DO?
Yes oil level is correct but where is oil level sensor ?Nothing has fallen out next to the starter motor. The blower cover and shielding isn’t positioned correctly.
All clean under engine cover, no grass or mice.Just got a mouse nest out of one today. I hate meices to pieces. Cleaned lots of them out of engines.
There is no oil level sensor.Yes oil level is correct but where is oil level sensor ?
Really? No oil leaks attracting grass and dirt either, all over the block and fins? Even under the air directing pan that goes around the block? Behind your muffler or any other areas?All clean under engine cover, no grass or mice.
