Rainbowjohn
- May 24, 2022
- 12
Yes I tried that thanks.Crack the fuel tank cap when it dies. Maybe your cap is not venting.
Really? No oil leaks attracting grass and dirt either, all over the block and fins? Even under the air directing pan that goes around the block? Behind your muffler or any other areas?
This must be a brand new or hardly used mower. But wait, the included picture, the lower block is filthy. Don't think your comment is accurate sir. I bet a cold beer that block is grungy.
Either you don't know where or what the top engine cover is or are calling the top side of the cover grass and mice free. Look UNDER the top cover. Look for some cooling fins.
Ignition coil tested and suspect so have ordered a new one, thanks.Is the block overheating?
Load test the ignition coil.
Fuel tank holding grass, grit and dirt?
Under engine cover spotless, engine only 18mths old but tractor 10 yrs old.Ignition coil tested and suspect so have ordered a new one, thanks.
Engine 18mths old, nice and clean under cover. Tractor 10 yrs old.Just got a mouse nest out of one today. I hate meices to pieces. Cleaned lots of them out of engines.
I see all kinds of sludge on the lower block area. Guess I'll take your word the fins are actually clean.Engine 18mths old, nice and clean under cover. Tractor 10 yrs old.
Yes I tried that after u said, it seemed to work longer before it dies.Crack the fuel tank cap when it dies. Maybe your cap is not venting.
You must have junk in the tank then.Yes I tried that after u said, it seemed to work longer before it dies.
