Carscw
- Aug 11, 2011
- 6,375
My SD cuts great,,only issue is the discharge opening leaves windrows in taller wet grass,,it leaves a scraggler here and there but only when the blades are getting beat,,just like any other mower I had,,and i had the best of the best....the tip speed is good..maybe people are having problems with the wide tires pushing grass down?
On decks with a anti scalp wheel in the front of the deck in the center also will lay the grass down.
