Marvinator
- Jul 28, 2019
- Threads
- 3
- 12
One of my first posts....I use a Cub Cadet Kt48, 22 hp riding mower. It has worked flawlessly for the last year and a half. I got it brand new.
Recently, I had a flat tire. No big deal, but once I got the flat fixed, I discovered that the other tire (rear) was over inflated to about 28 lbs!
Ok, so I put both under the recommended 10 PSI max and am again mowing my lawn. BUT now I notice that the mows are not flat. It appears that my cuts are angled. What could cause this? Checking tire pressure, I see that one is 8 lbs PSI and the other is 9 lbs PSI. Could this cause such an odd cut? Are there any other considerations I should check into?
