- Nov 29, 2014
- 24,995
I use Supertech 2 cycle oil from Walmart by the gallons. I use it in my string trimmers, chain saws, outboard motor and my Honda 50cc scooter also my golf cart and 3 wheeler with no problems. I been using it for over 17 years. It has been tested and rated for all the engines I use. It is inexpensive and burns very good. There is no reason to use anything else unless you have money to throw away or need a status symbol. It is rated TC-W3 which should be good for most any 2 cycle engine. If you are not comfortable with a TC-W3 oil there are a few brands that are around $10.00 per qt. I use so much oil I would be out of cash in a month or two. The choice is between you and your pocket book!
Yes & no
Using modern synthetic oils which have better mixing properties and cleaner burning, allows to use much leaner fuel : oil ratios.
Leaner mixes = more power which is good if the engine has variable jetting.
I run a lot of 2 strokes down here where we go over 100 deg in your money regularly with the ratio dropped from 30:1 to 50:1 without the slightest of problems
