The Chairman
- Aug 9, 2018
- 7
- 171
Thanks Max! Yeah, I've gone to the better bearings in the hubs, but mowing 30 ish acres a month for 9 months is a lot of mowing. I hadn't thought of putting in zerks in the towers, but that's a concept I'll research. I have a cracked tower I can play with to see if I like it.
As I'm mowing, it's obvious that the biggest problem seems to be getting rid of the grass under the deck. We had 21 days of rain in a row last month, so the grass is amazingly thick and lush. I believe as the grass accumulatesit's pushing the grass I want to cut down. I'm going to inspect under the deck to be sure all the baffles are inline and square and watched your Youtube on the blade guard with great interest. It definitely starts to accumulate on the rear portion of the chute.
As for the spring, that is on the drive, not the deck. I still have the original belt for the deck. I did find that the OE spring would allow the idler on the drive to allow the belt to come in contact with the starboard drive pulley, cutting it. In addition to the far better belt, I went with a stiffer and shorter spring, as well as created a 'limiter' made out of 150# leader. Since then, I haven't had a drive belt failure. [ceter]
A little background, I worked in automotive for thirty years, left just before the turn of the century. I also apprenticed in a machine shop while at UF. Now I am a Scuba Instructor and own/operate the largest forum/community for Scuba. I moved to the "cave capital" of the world, because I love cave diving.
