The responders in this thread are on the right track IMO.  We do need closeup pics of the sheared bolt halves.  Are there any circular marks on the blade clamp area which might indicate looseness which could lead to over heat and annealling (softening) of the bolt?  Any purple or brow color on the blade in that area? Or overheating and shock hardening (embrittling) of the bold on cool down or perhaps water is being used to clean the deck and "quenches" an over heated bolt?  If the bolts being furnished are a bit long or somehow the new bolt housing is under bored (depth) you could be torquing against this abutment when you think you are properly stretching the bolt.  Try making some depth measurements with a caliper vs length measurement of the old and new bolts. And , though doubtful if the bolts are OEM,  there have been many bootlegged low tensile bolts smuggled into to this country  .  Legititmate bolt head markings can be found that will identify the factory and also the grade.
Perhaps more info than you wanted??:laughing:
Buy a blue marker pen and take a reading of the bolt bearing surface after torquing . Both it and its mating surface should show contact. Do this also to the tip of the bolt.
Kept thinking ...if you use a lubricant like anti seize and do not reduce the required torque by up to 40% you could be causing the bolt to yield (stretch too far). There is a chart in this forum showing the lubricants and reduction factors.
