Well I’m happy to report that I got the SX85 running. It was a little lazy of me to ask the next step…what I was really saying was “ would you come over and fix this for me?
I decided I would take the flywheel cover off. After getting it off, I discovered a mouse nest underneath. It had chewed on a few wires, but not down to the conductor. I taped it all up. But what I noticed right away was how rusty the flywheel was. I have read several times from fellow users that the rust doesn’t make any difference. I like it clean and remove all doubt, so I used a grinder with a wire wheel and cleaned up the part that runs around the coil.
The coil was very covered in oil/dirt paste, so I took it off and cleaned it all up too. I think this was probably my biggest problem because with the rust and oil/ dirt mix, I don’t think there was much of a gap.
So reassembled to test, used my spark tester and it fired right up…
Off to my next issue which is it won’t move forward or backward. I’m wondering if the belt is making contact with the top pulley….
Any direction appreciated . you can come to Bolingbrook and help too. Lol
