PTmowerMech
- Apr 16, 2018
- 424
- 3,243
on a Briggs. 287707 0255-01 came in with the brass fuel inlet out of it. The inlet doesn't seem to go all the way in it. So, I'm guessing it's not the correct one.
Is there a way to fix this? I haven't seen a parts diagram where the inlet is separate from the carb. Only the plastic cap that fits over the inlet
He brought an extra carb that still has the inlet in it. But the brass was buggered up and had some sort of brown gasket maker stuff packed in and around it. I'm pretty sure a new plastic elbow/cap isn't going to fit on this. It's had a pair of steal pliers around the brass.
Here's what I got.
Here's what I got.
