Walbro Carb 799727
PTmowerMech
on a Briggs. 287707 0255-01 came in with the brass fuel inlet out of it. The inlet doesn't seem to go all the way in it. So, I'm guessing it's not the correct one.
Is there a way to fix this? I haven't seen a parts diagram where the inlet is separate from the carb. Only the plastic cap that fits over the inlet
He brought an extra carb that still has the inlet in it. But the brass was buggered up and had some sort of brown gasket maker stuff packed in and around it. I'm pretty sure a new plastic elbow/cap isn't going to fit on this. It's had a pair of steal pliers around the brass.
Here's what I got.
Would you check and see if the carb is threaded to accept a threaded inlet?
PTmowerMech
Sorry man, the pic was too large to post, I think I've got the size right now. It's not threaded.
How they got the old one off is not easy, as they are normally non removable. I suggest that you do a google search for Briggs fuel inlet fitting. There are a variety of ones that may fit.
PTmowerMech
Here's the other one. I just got it out of the ultrasonic. It looks like they put the pliers to it.
PTmowerMech
Ok, well about right now, I'm feeling like a big dummy. Where this fits into the carb, it's too buggered up. Some scratches.
But apparently this is the part I need.
Briggs and Stratton 692317 Hose Connector
Is it that easy?
I could tell you but it is probably over your head...:ROFLMAO:
Is it that easy?
Its that easy. Put some locktite or other sealant around the brass part and start it into the carb at the correct angle and then use your vise to press it into place. You can't drive it in because it will break and you can't rotate it after being installed because it will crack and leak.
PTmowerMech
I feel stupid now. And I have no excuse. Looking at the diagram, like 3 times, and didn't see it until just before I posted that.
:rolleyes:??
PTmowerMech
One of these carbs has a pilot jet, the other it's plugged. So it there no pilot jet on the one's that's capped off? This eliminates being able to drill out the pilot to keep it from surging.
I got lucky and found one that had a nozzle in it. It must be a newer style, because it's longer and made into the carb. It works though. At first, it poured gas, but I got it cranked and ran it for a little bit. Shut it off and watched it for about 10 minutes and nothing was coming out. Put a shut off valve on it, just to be safe.
