Boobala
- Feb 15, 2015
- 7,000
Are you aware of the problem with guides in these air cooled engines? Movement of guide in softened aluminum head (IMO) due to excess heat. In a later ? Briggs Intek 24 you could not buy guides ,only the complete head. My take after trying to reinstall guides with proper .002" press fit, but which moved again? Briggs knows you cannot succeed. I hope your head is an exception. Someone stated there is a loctite formula , but I could not find anything that would live beyond 340F a couple years back. Good luck, just my slant.
In SOME situations, when trying to get an item "locked into a "bore" (this procedure will work) in this instance you could have the guide "knurled" which will raise the surface material, then you could heat the WHOLE block ( in an oven) and freeze the guide then QUICKLY press the guide into the block .. sort of "shrinking" part A and "enlarging" part B .
