mixotricha
- Nov 3, 2021
- 2
- 20
Of course the alternative would have been to swap the steering over so that it came out the right side of the mower instead of the left. But the way Rover designed the steering it cannot be flipped. At least not that I can see. Also the tracking arm on the steering isn't on a spline! What I did to get around that was to rotate it 180' with the split on to the key. That is a bit dubious so I might end up putting a tapered pin through it when I am done or similar.
