- Sep 24, 2017
- 250
- 6,441
What are y'all using for a cleaning solution?
I buy this stuff 3 gallons at a time. Mix it 50/50. Cheap and works pretty good.What are y'all using for a cleaning solution?
Strange I only started rebuilding the cubes back in 2009 and rarely have problems with them except the Stihl mounted Zama carburetors which in the last couple years started having primer check valve failure along loose welch plugs which none of the kits contain the welch plugs that are problem ones. Those welch a lot of the time are missing before I get the carburetors [with a few coming out in the USC during the cleaning process].I use simple green and LRC and water. Note: 2 cycle carbs - In my opinion are no longer rebuildable. It took me 2 years to make that decision 5 years ago based on the check valve either open or stuck closed due to ethanol. I rebuilt those carbs for 45 years with nearly 100% success until ethanol arrived.
Don't know for sure if it is ethanol or not but you are right about check valvesI use simple green and LRC and water. Note: 2 cycle carbs - In my opinion are no longer rebuildable. It took me 2 years to make that decision 5 years ago based on the check valve either open or stuck closed due to ethanol. I rebuilt those carbs for 45 years with nearly 100% success until ethanol arrived.
