Ultrasonic cleaner questions
cdestuck
Thinking of getting a ultrasonic cleaner to cleaning out carbs. Wondering if you guys have found a decent buy on a cleaner? And what kind of cleaner fluid do ya use in these. And how long to you usually leave a carb in these to get a good cleaning. Thanks
Harbor freight has a good inexpensive one. After trying about a half dozen different cleaning products, we found that the powder which harbor freight sells works the best for us.
cdestuck
What kind of time are we talking about to give a carb a good cleaning.
Gsnod
I see that Harbor Freight has their Chicage Electric 2.5 liter ultrasonic cleaner on sale right now for $69.99, a discount of $30....I'm thinking about getting one also.
tybilly
let us know how that harbor freight ultrasonic machine works out,right now im just using a gallon of chem dip wich works good,
briggs
yes i would like to know how it works also ..If it works good i will try it
You won't regret it. It's works so well that we have gotten to the point where 90% of the carbs in our shop are put through it when we are doing a tune up. Just remember to clean the exterior of the carb before disaasembly, as the solution will last longer. We get about 5 carbs through before needing to change the bath water.
cdestuck
What are you using for your bath water?
briggs
What do u use for bath water ..Right now i use a 50/50 mix of high test fuel and sea foam to clean them ..But always looking for a better way
Read post#2, powder and water.
