still waiting to try out my exmark 30. the wheel adjust does concern me only because I change wheel height often as many customers like it different heights. the mulch plug is also a concern until I have a chance to try it out.
im considering buying this mower but its kinda hard buying something sight unseen. would this make a good main mower for a 10 lawn schedule with no trailer? can you use self propel without the blades?
does it clog up more than a 21" mower?
how does the self propel do on hills? can you hold the mower back and spin the tires on pavement? I ask because I used my friends sr4 and I had to push it up hills
Ok to start with your hills and mine are going to be different, remember I'm in Florida and I have slopes :smile:. Any hills that are here have not been a problem. As far as holding the mower back and spinning the wheels on pavement that I've never tried but I know the mower has enough power you'll play H-E two sticks try to hold it in on spot when the drive is engaged and keep in mind that the drive on the Turfmaster is adjustable for your personal comfort level.
I seen one review where an individual claimed that the Turf master clumps there grass or it's under powered and it's simply not true. 90% of the people who make those claims have no clue how to run the mower or cut grass correctly. That 90% will go out in there yard with six or seven inch high grass and try cutting it down to two and a half inches and wonder why the grass clumps and the mower powers down.
How about grass that is 4-5 inches tall?
Lets say as you asked your grass is 5 inches tall, what height should the mower be set to remove one third the height of that grass or how many inches of grass do you remove?
I should set the mower at 3.5". But I usually cut at 3.0".
If you have grass that is 5 inches tall you should remove no more than 1.6 inches to keep the grass and its root system healthy and the mower cutting correctly. That's the problem, to many people would cut the grass down to 2 or 2 1/2 Inches and then when the mower clumps grass and powers down they blame the mower because of what it's doing when in reality there trying to make the mower do something it's not capable of doing.
The thing is I try to stick with cutting at 3.0" because if I cut it higher than I would need to come back sooner to cut it again and I don't have time to come back like 3 days later!![]()
I agree here. 3 in is all I cut down to doesn't matter if its 10 in long if I cut 10 grass to 6 in then it grows 7 more in the next week I come back it'll be 13 in long then I cut it at 8 in tall come back in a week and it'll be 16 in long not a good pattern when I can only get to a lawn every 7 days
You have to remember that grass is like 80% water and when you remove more than a third it could or can send grass into what's called physiological shock, which leaves the lawn prone to invasion by weeds and less able to cope with drought and other environmental stresses. If the grass gets so long that you can't get it down to proper length in one mowing, wait a day or two and mow again. The more often you mow and the less grass you remove with each mowing the thicker and healthier your lawn is likely to become.
How excatly am I supposed to do that. Go back in two and three days? I am in a different part of town every day they are on either 7 or 14 day cycle the grass does just finebeing cut low. Temps get 100 degrees and dry and the grass grows just fine.
I think he my have been talking about if its your own yard.
But he is right you really never want to take more than 1/3 off the height of the grass. Even trees or shrubs never take more than 1/3
If you have yards that are on a 14 day cut and they are getting over 6 inches I don't see how they can look good. Years ago I had homeowners want there grass cut every two weeks cause they said it don't grow I hit them hard with fert and had to cut them every week.
(( racing is the only sport that you need two balls ))
My every two week yard probably classify more under weed mowing... the people who really don't care.
I understand.
How exactly am I supposed to do that. Go back in two and three days? I am in a different part of town every day they are on either 7 or 14 day cycle the grass does just fine being cut low. Temps get 100 degrees and dry and the grass grows just fine.
I love my turf-Master, have no problems doing ditches or small hills, I don't mulch only side discharge but shouldn't be any difference.I am looking at buying the Turf-Master. After reading everyone posts I'm up in the air about getting it now due to people saying it dosen't have enough power to go up hills.
Here is my situation. I have one customer that does not want me using my walker mower on his lawn, as it keeps leaving divots. His lawn seems to be very thin and wet all the time and i assume its part grass and partly the way im using it. I am considering buying the Turf-master to use on his lawn so that i can get it done quicker. I will most likely be using it on other lawns. I don't bag, I always mulch.
My questions are
Is it worth paying out $2000 for this machine to keep a customer that gets me to do his lawn/fall cleanups/hedge trimming?
How many people are having problems with this machine on hills. Most of my places i will be cutting are flat. There may be a few small hills.
Would it be better to buy a 2nd 21 inch machine and just run them both at the one property?
How much time do you save per lawn by using the 30 inch turf-master?
Thanks for any help.
My questions are
Have had my TurfMaster for 2 1/2 months now and have only 1 frustration with it. Regardless of how I set the height setting I am having to double back over my rows due to 'Stragglers' of grass not being cut. Does not matter how high the grass is or the type of grass being mowed.
I cut St. Augustine grass 90% of the time. Have already changed out my blades and still no real positive change. Have also been setting the back wheels 1 notch higher than the front.
Suggestions? I am wasting a lot of time re-mowing and need to find a solution to this somehow.
Thanks,
Bill
Have you changed out the belts yet? It sounds like the belt is loose or about gone and your not getting the proper BTS.
The handle is attached at 3 points on each side. It is not designed to move.
