Ric
I purchased the Turf-Master as a kind of replacement mower for my Cub Cadet G1336 Walk Behind mower. For the money I was spending I was a bit skeptical at first and more so buying it sight unseen. The Turf-Master is basically a cross between my 1336 and a rear-bagging self propelled mower, it's a lot easier to handle even at 167 lbs than a 400 lb WB mower. It's a perfect mower for residential yards and has the best cut of any self-propelled push mower I've seen or used, it gives the operator the best of both worlds. Unlike the the larger WB it gives the operator the option of being more of a detail mower along with a 30" cut with considerable time savings over the the standard 21" mower and the wheel height adjusts are fantastic.
To those who are thinking about the Exmark 30" that is basically the Toro I would say check the mowers out carefully because there are some differences between it and the Turf-Master, Like the Turf-Masters Bull Nose Bumper, Deck skid Plates and Wheel Adjustments gives the Toro a leg up on the Exmark in ease of use only because it to is an excellent mower.
In closing if you are hesitating on the purchase of The Time-Master, Turf-Master, or Exmark 30" don't hesitate any longer, You wont be disappointed. :thumbsup::thumbsup:
