My sisters husky is having issues with smart switch I suspect, mower starts ok then you engage blades no problems, then mows fine, when you disengage the blade switch the engine shuts down. It does it fairly consistently, I have an electrical trade background so have bypassed and checked the interlocks as per the wiring diagram with no change to the fault.
I see a lot of people have had weird things occur with faulty start switch logic, but they are expensive to buy and I won’t be popular if fault is still there. Have thought about installing old style ignition switch set up and get rid of the smart switch, if anyone has some good info on that process that would be great.
If anyone has had similar issues and found a fix your info would be appreciated.
