primerbulb120
- Nov 3, 2014
- 43
- 1,315
If the current rope is in good condition, you shouldn't have to replace it. The rope should still be intact after disassembly. If the crank is warped, however, you would have to replace the crank housing, which comes with a rope installed. The crank housing is about $20, you might be able to get one cheaper on eBay.
