Troy Bilt Self Propelled Lawn Mower Issue
stemo99
I had a Troy front propelled mower with the same problem. The wheel drive shaft is held by bronze bearings that wear out and allow the drive shaft to move and not engage with the wheel gear teeth. Raise the front off the ground and if you can wiggle the wheel up, down front or back at all the shaft bearing is worn out. I have since converted my Troy to a push mower.
eddie57
Is the shaft bearing you are referring to the picture I posted on this thread earlier? (reply #5 on page 1)
stemo99
My bearings were bronze that mounted into the actual deck. They were severe egg shaped and to replace the entire shaft wouldn’t be cost effective. I removed all the drive stuff and now it’s a push mower. good luck.
TroyBilt part number is 641-00014 when I look up your unit. To me it looks just like the one posted.
eddie57
Thanks. Part isn't expensive. I am going to order two of those plus the two spur gears. Total cost around $30. If it doesn't work I will convert it to a push mower.
eddie57
I replaced both bearings and the spur gears and it seems to have improved the performance. I have only used the mower once so time will tell. Thanks
