Troy Bilt Self Propelled Lawn Mower Issue
eddie57
Hi, I have a Troy-Bilt Walk Behind Lawn mower that is self-propelled, front wheel drive. Recently the right front wheel doens't seem to be self-propelling. If I lift the front end up it will spin but when it's on the ground doesn't. Does anyone know what the problem might be? Thanks
Model No: 12AEA29L011
Model: TB270 ES
Two things will cause this problem. First would be a worn drive belt. If it is three plus years old, time to replace. Second would be a a worn drive gear on the right drive wheel. Again it may be time to replace.
eddie57
The belt is in good shape. The left wheel propels great. I took off the spur gear yesterday and it looks okay. I'll post a picture later to get your opinion. Thank you for replying.
Then it probably the bearing assembly binding up on the axle.
eddie57
eddie57
Attached are a picture of the Spur Gears from my Lawn Mower. I also included a picture of a new spur gear. I think the gears from my mower look fine. Any comments are appreciated. Thanks.
The used gear on the left is definitely worn. Check the axle for play, it should not move up/down or side to side. If it does, it may be the bearing Star posted and you have pictured.
eddie57
Thank you. I will look into it.
eddie57
In regards to the drive shaft bearing, if it is worn, is that the reason the front right wheel isn't turning when the self-propelled lever is depressed? Thanks
A worn bearing will allow the axle to move, not allowing the gears to mesh properly.
