reynoldston
 - May 23, 2011
 - 92
 - 5,705
How you load a trailer and what you load it with really depends on the physical size of the trailer and it's load ratings. In my case knowing the weights of every piece equipment makes a big difference in how and where it gets loaded and mounted and it shouldn't be a waste of time if you care about safety. Trucks have pull ratings as well as load ratings. Pulling with a light weight vehicle is fine as long as your pulling something within the vehicle's tongue weight and recommendations.
This is the reason I have the use of 5 different trailers and different tow vehicles. My smallest trailer 1000lbs., pull able with a car and for smaller equipment and good gas mileage, to a triple axle trailer good for up to 18,000 lbs. pulled with a HD 1 ton dully diesel for small dozers. For 99% of my trailer needs I would say I use my all aluminum trailer 2000 lb. rate with a loading ramp and pull it with my car. Being in the repair trade no two loads are the same and most of the time not runnable or moves on its own. Most of the time just a come-a-long to load lawn equipment to a 12,000 lb. pull rate electric winch for full size farm tractors to pull unto the trailers. For really large equipment we have to hire a lowboy. At my age the heavy equipment is for my son in law and grand son to handle, repair, and play with. For me its lawn mowers and cycles.
