Hi,
My Toro 15-38HXL will not start. It behaved like a bad battery: A brief clicking sound when turning the key, then nothing. Tried to jump it off from the car, but it did the same thing. At that point I should have suspected something else, but I thought the battery was so far gone it wouldn't take a jump. So I put a new battery in.
Did the same thing. Now I suspect the starter. I removed the started, hooked it directly to a battery and it spins and the bendix gear pops up every time juice is put to it. So it must be something between the battery and the starter right?
This is the extent of my knowledge. What should I look for next? Is there a relay or something after the ignition? I assume the ignition itself is okay because I did hear some clicking at one point after turning the key.
Thanks in advance for any advice!
Bill
Bill
