lightadjust2000
I'm having this same issue with a 6 year old timemaster, changed oil, new plug, new fuel filter, new blades, new air filter, new ignition coil, new gas cap. all parts have been oem. i even dropped the carb and cleaned the bowl (it was spotless anyway). the symptom ocurrs only when its above 80ish outside...seems i can prevent it by quickly letting go of all handles and letting it run idle for 30 seconds, only to start up again and 5 min later the issue happens much quicker and i cannot prevent it. if i try to restart, it wont even spit, almost like there is no spark, which is why i replaced the ignition coil. any more ideas?
