Gooser
I've got a Toro SS5000 model number 74631. It starts but the electronic brake won't release. This spring the starter was stuck so I replaced the battery and starter. Now it starts but the E brake is stuck. I have replaced the electronic brake module, the solenoid, the switch and the two switches under the control handles. If I manually release the brake as soon as i turn the ignition on the brake sets again and will not release. Any advice would be greatly appreciated.
