- Nov 29, 2014
- 24,995
IF you installed the carb with the seat not fully home so the float is not sitting horizontal the fuel level in the bowl will be too low so the engine will surge when running on the man jet
The hole that the red rubber seat goes into is not strait
Down the very bottom there is slightly smaller diameter section to hold the seat tight I think your seat is sitting on it and not in it
A touch of silicon spray goes a long way to getting it to seat properly
DO NOT USE WD40 beause it will make the rubber go soft
