Toro model 70040, brigs and Stratton.
guins66
Hello. Have 96 toro workhorse and can’t any spark. Replaced starter, battery, ignition switch, starter solenoid, plug and still nothing. Any ideas.
:welcome:
Bet you bought them all on line to save money because if you went to a mower shop they would have told you that none of those parts are in the ignition circuit apart from the ignition switch.
The only parts in the ignition circuit is the magneto, the ignition switch and the PTO safety switch and the brake switch.
Remove the blower housing and remove the small wire from the coil
If the mower starts then you have a bad safety switch.
If it does not start then the magneto module is bad.
guins66
:welcome:
Thanks, I will try that.
guins66
Forgot to ask, you said maybe bad safety switch. Where is that located? I also changed out the seat switch.
guins66
Update pulled the wire and still nothing. Guess maybe magneto.
Before you put the new one in there, check the wire you pulled off.
It should be open circuit with the ignition turned on and ground with the ignition turned off.
If it shows voltage at any time then there is a big problem in the wiring .
Do not connect the new module till you have sorted that out because applying battery voltage to the magnet will kill it dead flat.
guins66
Changed out the magneto and still nothing. Just a clicking noise from the starter relay. Any ideas how to isolate the problem would be appreciated.
guins,
Please be a bit more specific with your posts.
Still nothing is not much to go on.
From the start, was the engine rotating ?
If the flywheel does not turn the engine can not generate an spark.
If the flywheel is turning too slow it will not generate any spark.
If the engine is not turning and the new solenoid is just clicking then generally that is caused by a flat battery or corrosion on one of the main power wires.
starting with a freshly charged battery try the following
Simple to check.
Run a jumper from your battery - to the engine block.
Mower starts fine = bad ground
Run a jumper from your battery + to the hot side of the solenoid
Starts fine = bad power supply wire
Do the same as above to the starter side of the solenoid
Starts fine = duff solenoid
Dosn't start properly = duff starter
Before you do any of these check the valve lash.
I get a dozen "unfixable" mowers in every season where the owners have replaced some or all of the following for a cost of around $ 400 when all the mower needed was a valve adjustment.
Starter motor , solenoid, battery, ignition switch , PTO switch, Ground lead, Power lead.
guins66
Thanks I will try your latest suggestions. Hopefully I didn’t fry the magneto as you said before. What I mean by nothing is that it doesn’t try to start at all. I checked the seat switch and it’s working. Checked the voltage on pto switch and it’s good same with neutral safety. Battery is new and has a full charge. I have power to the lead that goes to alternator so assuming it has power since I can’t check because I put everything back together. Checked the ground it’s clean and tight.
UOTE=bertsmobile1;280440]guins,
Simple to check.
Starter motor , solenoid, battery, ignition switch , PTO switch, Ground lead, Power lead.[/QUOTE]
guins66
Think I replied to the wrong thread. New at this forum thing. I was able to get the engine to rotate by touching the negative on the starter solenoid and the other lead the engine. Does that tell you anything? Sorry, but electrical is not my strong area.
