Toro model 20331 6.75 Briggs no choke/no prime cold start issue
sgkent
  • / Toro model 20331 6.75 Briggs no choke/no prime cold start issue
Always is good to hear someone solved their issue. Thanks for sharing.
oldntired55
Gentlemen, you tips proved most helpful. I discovered two problems. The coil I replace earlier had a slightly larger profile and cause the vain to drag across it. I corrected this by simply sanding down the corner. Also, someone actually assemble the machine incorrect by attaching the thermostat arm to the vain, this has been corrected. Machine now cranks easily and runs like a new one.
Your assistance was most appreciated, Ray
ive seen that issue before...a backyard handyman incorrectly assembled choke parts
scoyote
I've seen this a few times---you choke isn't coming off as it should--if the air vane isn't rubbing he problem is at the thermostat end --if the arm guiding the air vane springs back it's ok--problem in my couple of cases was that the travel was too much and the air vane got hung up --bent the thermal arm to limit the vane travel and it moved off choke as it should
Steven65
HEAR SO MANY THINGS! Use a tat of Heet in case water in tank. Red bottle. It will stop it! Works everytime!
Steven65
Let me know when it fires up lol
kbowley
Remove the fuel injector and soak it in bug spray! Works every time!
