patrmich
- Mar 28, 2026
- 2
Hello,
1- I have a Toro 21090 electric lawnmower, 21090 cutting width, which I've had since 2007.
I just hit a stepping stone. Since then, the mower has been making an unusual noise, so I haven't tried using it again.
The blade doesn't seem damaged. It turns by hand, but with a little force, it scrapes.
2- Do you have any idea what might have happened?
3- Should I remove the blade? (The retaining nut is plastic, and I couldn't get it loose using a 24mm open-end wrench)
4- To access the motor, I tried to lift the black cover, but I only managed to unclip it at the front.
5- Under the casing are four 10 mm diameter nuts. But when I try to loosen them with a socket wrench, the nut and bolt turn at the same time.
Do you know how to remove the black cover?
6- Do you think the lawnmower is repairable?
Thank you very much in advance for any help.
Sincerely,
Patrick
Sincerely,
Patrick
