- Feb 19, 2020
- 118
- 12,664
Look IL is right about the 310000 series being a cross flow head of sorts. The intake port and exhaust ports are about the same height; therefore, intake port must cross over downwards (about 30 degrees) to the intake valve. Now the exhaust valve does have a straight shot at the exhaust port. Either way the paths are not a prefect criss cross but is very close. A true criss cross flow it is not. The old L heads the intake valve is always on top (magneto side) and the exhaust valve is on the bottom (PTO end).Sir you are wrong I’ve been to many schools and replaced many of these so unless you have a picture to prove your correct then you are not.
As far going to schools I haven't been to a single small engine school in my life.
One advantage of this head design is the less fuel waste as all ACR vented fuel mixture is to the intake, One drawback is there is no way to fully clamp the head gasket in the area where the intake is crossing over leading to lots blown gaskets.
Now IL is wrong about the only Briggs 19 hp engines with the ACR on the intake as not only the 310000 but the 210000, 280000, and 330000 series also uses the same camshaft and head design. So far the most common ACR failures on these camshafts I have seen is only on the 310000 and 330000 but the camshaft is the same one in all four series. I just replace two 21hp 793880 camshafts this month alone.
