I operate steam dryers primarily producing instantized corn grits. I work in an uninsulated/non-air conditioned steel building and summertime temperatures where the dryers are located often approach 175コF. And did I mention I work in steam?
100コ and 'high humidity' and I don't even begin to break a sweat. :laughing:
Drink lots-o-water. 'Tis nothing to drink 5 gallons worth per shift when it starts to get really warm.
5 gallons is a lot.
I drink about 12 green tea a day that comes out to 202.8 ounces so about a gallon and a half plus two 24 ounce coffees every mourning
I seriously doubt your drinking 5 gallons worth per 8hr shift. I don't think your body could stand that much water.
Man you guys are going to kill yourselves, your drinking way to much water and when a person drinks too much water in a short period of time, the kidneys cannot flush it out fast enough and your blood becomes waterlogged. It gets drawn to regions where the concentration of salt and other dissolved substances is higher, excess water leaves the blood and ultimately enters the cells, which swell like balloons to accommodate it.
No one has complained about biting insects, but there must be many in the south. Out here May is deadly due to May flies . They are "no-see-ums" and bite the white under arm and face. The bites cannot be felt until later when they are like flea bites. Some neighbors stay indoors to avoid them. If the "deet" in bug repellants scares you, try the eucalyptus based oganic spray bottle. Just a little bit will "do ya."![]()
