throttle linkage diagram, high revving regardless of throttle cable setting
Forest#2
  • / throttle linkage diagram, high revving regardless of throttle cable setting
I actually DID do just that, with no change... when it fires, it revs out of control. i have a parts engine,i am pretty sure the gov gear is toast... i just need time to tear the 2 down. but ty for the info!!
I recently had same problem as you with one of those twin Inteks. It was a new to me engine that had bad carb plus other things and people had be flogging the engine creating numerous issues..
When I got it cranked up it would go to max throttle but would slow idle if I held the carb manually. I was thinking about pulling the sump and checking the governor but one last attempt at the slow idle static adjust, I got results.
The governor shaft coming out of the engine was actually slipping in the the governor arm. The 7/16 locknut had to be really snug and not limp wristed. Had to use a 1/4 inch drive ratchet with a 7/16 socket and get it good tight.
Problem solved.
If it is broken inside the block be sure and find
all the pieces of the puzzle or the gears will eventually find them.
oldntired55
Problem solved.
ok thanks for the info, i can manually pull it down to idle, or , use a spring to pull it back...ill check that and let you know!!
oldntired55
So, after tearing this engine apart for the THIRD time, with a gov issue... i found this in the sump/crankcase...i realize that governor shaft is NOT supposed to come out, but it did, and it ruined the new governor. have another one ordered... in the mean time, i put of some of my limited machine shop skills to work, i drilled and tabbed the block for a 1/4 inch set screw... yes i realize thats a hardened shaft,after some careful measurements and blue dye, i ground a few notches into the shaft, for the set screw to bite on. also , took a prick punch inside the block hole, and put a small dab of JB WEld on the shaft, wiping clean any excess that oozed out. then, tightened the set screw(with Loctite)..and staked it in . the gear is on and holding now. wish me luck when i start it up... if it doesn't work, ill be tearing down another v twin and using that block!!!
oldntired55
So, after tearing this engine apart for the THIRD time, with a gov issue... i found this in the sump/crankcase...i realize that governor shaft is NOT supposed to come out, but it did, and it ruined the new governor. have another one ordered... in the mean time, i put of some of my limited machine shop skills to work, i drilled and tapped the block for a 1/4 inch set screw... yes i realize thats a hardened shaft,after some careful measurements and blue dye, i ground a few notches into the shaft, for the set screw to bite on. also , took a prick punch inside the block hole, and put a small dab of JB WEld on the shaft, wiping clean any excess that oozed out. then, tightened the set screw(with Loctite)..and staked it in . the gear is on and holding now. wish me luck when i start it up... if it doesn't work, ill be tearing down another v twin and using that block!!!
i also realize it was a lot of time and extra work, but i never in my 45+ yrs of being a ,mechanic, was one to 'give up'. i wiull beat this thing...one way or another!
TEXASCOUNTRYBOY59
To see if the governor on that OHV twin Intek do a static governor adjust but INSTEAD OF rotating the governor shaft in same direction as the governor arm, hole the carb throttle open and TURN THE GOVERNOR SHAFT CCW OR IN THE OPPOSITE DIRECTION.
If the internal engine governor is operating and the governor spring is connected the engine will low idle if the throttle is set to slow speed when the engine is started.
This adjustment is just the opposite of what normal static governor adjustment per the manual but it will let you know if the governor is capable of pulling the throttle to slow speed.
Let us know the results of the above and we can then tell you how to get a governor control for that TWO BARREL NIKKI CARB.
Sometimes a Bubba has been making bend adjustments to the slow idle governor control linkage or even removed some parts.
The Briggs Twin OHV Intek service manual is a good reference at about
$30.
TEXASCOUNTRYBOY59
$30.
I got Tom Sawyer'd by a cousin to look at his Snapperpro, has or so he says a briggs 27hp twin,had gas running out the muffler when started, thats my guess the solenoid in the bowl? but to make matter worse, when it is started it runs wide open, throttle cable wont move the rpm. I looked and the governor is holding it wide open. I wedged a screwdriver to pin the idle screw down to its idle position. that stretched the gov spring, (didn't bend anything), purrs like a kitten. how do I adjust the governor to get the preload off tat spring? CCW? I started to mark the clamp and rotate it CCW
