Yeah , got 2 emailsJust let me know if you get two emails. I still learning the FF Relay add-on.
EDIT: Now I know how the free Relay account works as I assume replies are not normally done except with the premium account.
Thanks
Don't know what they were worth new in the USA but they were $ 8,000 down here more with a Kawasaki engine.Got it running and drove it around the yard. It is an interesting machine. Pulled the deck. one spindle had the blade hit something and buggared up the plastic pulleys and froze bearings and broken gilmer belt. Middle spindle has growling bearings. Both belt idlers have shot bearings. Guy wants it fixed $$$.
It has the Bio mulching deck.
It does not have that type of blade adapter or blades. The blades have a single hole in the middle and blade adapter is just round.If the blades overlap then there has to be a shear pin or they can strike each other if they get out of time
Part 506 94 55-01 in the diagram below which came from K & T web page if Star did not send you one
Despite there being 2 in each blade pack, you only fit one at a time
Bummer about the deck not flipping up
I have the dumped mowers here, plus 2 of the US cheapie version plus a Pro-Flex and they all have flip ups so I assumed that all of them were flip up.
Yeah the first one was scary using the press. Second ine will be a challenge not to break the housing. I know what you mean about NLA parts.Just be careful as You need to make sure the part you are pulling or destroying is available. I having a lot parts lately being NLA.
