- Nov 29, 2014
- 65
- 24,995
You have just opened a can of worms with that one.
Using 5W 40 will not hurt your mower.
It is not as good as proper mower oil, but if it makes things easier at your end the use it.
The caveat is you really should change it at the end of every season, just after you have done your last mow of the season so the engine has nice clean oil in there over winter.
The main difference between mower oil & car oil is the anti corrosion package.
If the oil you have for your car has high zinc ( and it should ) it will be fine for your mower.
Being a 5W oil, it will tend to find every possible exit point but as long as you check the oil level before you mow ( and every one should always do that ) it should not be a problem.
Back when i was running hire cars, courier bikes & vans we were drowning in 5 different oils.
My business partner made an executive decision to buy 20W 50 in a 44 gallon drum and just change the oil a little more often.
We did about 10,000km / year with each RR hire cars, 120,000 km / with most vans ( toyota, mitsubishi & nissan ) and about 150,000km / year on the motorcycles.
There were no oil related problems from any of them over the following 13 years and we saved a fortune on oil & more important time running to the parts store buying drums of 5 different oils.
Now days my van runs on mower oil because I buy it in 44 gallon drums, & it gets an oil change every 3 months.
Apart from being a little noisy on start up and a few drips it has not given me any problems over the past 6 years.
With oil the most important thing is how long it has been in there , what was in there comes in a close second.
