Boobala
- Feb 15, 2015
- Threads
- 200
- 7,000
Re: MTD Yardman Transaxle Rebuild
AYYYYY...AYYYYY....AYYYYIIIIIIIIIIIIII it's cold outside, first time I've seen it this cold in Central Fl. I must be living right or something, in the home it's staying between 72 & 74 deg. and it's 23deg. outside, since the last cold spell I've learned a few things, last time I had my "stat" set at 76deg. and the heat-strips were kickin in constantly, so I lowered the stat to 74deg. and the heat-strips didn't come on, the heat pump is constantly going right now and cycling ( goes into it's de-frosting mode and blows cool /recirculated air then heats again ) if I put it up to 76 then the strips come on again, I can easily live with 72-74 deg I can't figure these things out, although I've read a ton of info on them, last Elect bill was $147.00 really not that bad considering I've got a 3/2 with over 1300 sq. ft. , but the highest bill for the past year, see below,
Anyway the weekend is SUPPOSED to start the warming trend ??? got the frost proof outside faucets (we'll see) and an old one, is set to drip, ( still to dark to see) hopefully everything is OK ! daylight will let me check the meter-flow, SOOOON !
ANYWAY I hope everybody is warm this frigid morning ...I guess if you're still warm & breathing, ..then it's a GOOD Morning
...![-Grumpy-cat-MEME-LOL-Funny-Pictures.jpg -Grumpy-cat-MEME-LOL-Funny-Pictures.jpg](https://www.lawnmowerforum.com/data/attachments/30/30029-c908dcc6b27c23a6e86709835bf4703b.jpg)
![the-three-most-romantic-words-to-say-in-the-morning-coffee-is-ready.jpg the-three-most-romantic-words-to-say-in-the-morning-coffee-is-ready.jpg](https://www.lawnmowerforum.com/data/attachments/29/29098-4ea20d42a0c05bc55bcc2777a3d2b21f.jpg)
