Boobala
- Feb 15, 2015
- 200
- 7,000
Re: It was all a matter of alignment!!
And meanwhile , back in the workshop, the spider continues to weave his web inside the carburetor venturi of a lonnnnng
forgotten & forsaken once ever dependable MTD Yard-Man riding mower,...
Here's the straight-skinny on the Troy-Bilt pulleys.
I very carefully checked and sure enough, if I really paid attention and look carefully, I could see that the pulleys were not exactly aligned one set above the other. In fact some careful measurements indicated that they were off by 3/16"! In this case the pulley need to be 3/16" further away from the motor. As I found five shims on the shaft of the Tecumseh engine, I measured three of the thickest ones and found they were 1/16" each, so I put all three on the shaft of the Predator. Then I put on the extra two belts I had ordered for the 1976 Tiller and put everything back together. A little tension readjustment for both the belts and the reversing wheel and it ran great!
I drained the break-in oil and refilled the Predator crankcase with a good 10W-30 oil and hopefully it will now work fine. When I finish refurbishing and repowering the 1976 Troy-Bilt, I can assure you that I will pay far closer attention to the pulley alignment.. I've always said, "If you don't screw-up once and a while, you aren't really working!" In my case I always seem to be working!!
I just ordered two new Kevlar belts using the same supplier but the other Troy-Bilt number. There is a GW-9245 and a GW-1128, I want to see if there is any difference between them.
I 'think' we're good to go with it now.
Roger
