Roger B
- Oct 19, 2016
- 11
- 1,656
JD GS-25
Boo-Boo has suggested I use Transmission fluid as a crankcase cleaner and that sounds like a good idea. I have to replace some of the fuel line as it was left disconnected where a fuel filter would go and I discovered the old hose is plugged with crap. I need to check out the end coming from the fuel tank as well.
My current problem is still electrical. All though the ignition system on this unit is very simple, the safety and shut-down circuit (which grounds out the coil) is interconnected with the electrical generation system that creates the voltage necessary to operate a couple relays and the electric PTO clutch. A relay in this system has a couple diodes connected to it and if it is plugged in to it's socket it will ground out the coil and thus far I am unsure as to exactly why.. One of the diodes may be a 'zener' and they act sort of like a valve, in that they shut off DC electricity until it reaches a certain potential and then they 'break-down' and allow the voltage to pass through. Without a schematic and operational description of this circuit, I am at a loss as to how to troubleshoot further than I have so far.. I think I am going to go visit my local JD Dealer and beg assistance.
Roger
Roger
