Re: MTD Yardman Transaxle Rebuild
That's exactly what I did without even seeing your reply. I ground a taper on the old pin, put that in the right side then drove the new one in from the left with the nut on loosely so I wouldn't bugger up the threads. I got it to the point that it drove the old pin out and couldn't get it any further. I had to wait until wifey got home to tap it through the rest of the way while I lined it up. I'm all set now except I'd loosened that 9/16 adjuster bolt that's right below the arm from the trip springs. I didn't know if that would help line things up or not but was desperate, lol. Now I just need to adjust it back so the plow sits properly the next time I put it on the truck. I removed it and it's setting on the garage floor for easy hook-up. It can be a bit of a pain to get the plow on if I drop it on my uneven gravel. I liked the chain hoist on my old Fisher because all I needed to do was get close and chain up to the hoist and I could move the plow around and line it up.
Thanks for the help Doc! Better working conditions where I didn't have to keep climbing over the plow to get to the other side, the right tools and a helper would have made it a lot easier.
P.S. - I had a round bar that I could get in and wiggle around but the diameter is a little bit too small so I couldn't quite get it lined up. Wifey was my savior!
