Boobala
- Feb 15, 2015
- 200
- 7,000
Re: Garage door update
I'll buy that, .. OYYY VAYYYY .. sooooch a deeeeel ! .. evvvvv yeee booodeee shoood haaaf one !! .. ( OLD Country dialect !! )
Top filler panel mocked up and installed.
Fit is good, but ran into a roller issue.
Having 2 rollers close together was fine on the curve, but as they entered the straight section, the top roller, being farther away from the panel as it landed in the arc, would require some relief on the lower outside edge of the joint between panels in order for the door to flex backwards.
I could probably do that, but I found the easier option was to remove the roller at the joint between panels.
There is no noticeable weakness at this joint doe to the missing roller.View attachment 36122 View attachment 36125View attachment 36123View attachment 36124
