The Daily Yardman Thread
Boobala
Re: Garage Door - addendum
Hey, Roger,
I'm going with spruce.
Less $$$ and available closer to home.
Gonna paint, then put aluminum skin on outer surface to match the surrounding door trim on house.
Should be unnoticeable, but will open with the door.
Coulda just used an over-sized shower-curtain and been done with it by now !! ..:laughing:..:laughing:
Ronno6
Ever heard of Rube Goldberg??
What am I talking about..............he's your IDOL !!!
primerbulb120
Re: MTD Yardman Transaxle Rebuild
I created a system for use with the Cyclone Rake that was supposed to put the leaf debris in trash bags. It began to work, but the air exhaust screen got clogged with leaves and blew the lid off my trash can. Grr.
BlazNT
Now you know one way not to do it. Next!!!
BlazNT
Total views 599
BlazNT
Morning Ted
Morning all you stayers and newbies.
Boobala
Well my "fair-weather friend" , it's called ... KARMA ..!!
Ronno6
Boobala;287342 ANNNNND the thought 4 2day : [ATTACH=CONFIG said:
36121[/ATTACH]
AMEN to THAT !!
Ronno6
Garage door update
Top filler panel mocked up and installed.
Fit is good, but ran into a roller issue.
Having 2 rollers close together was fine on the curve, but as they entered the straight section, the top roller, being farther away from the panel as it landed in the arc, would require some relief on the lower outside edge of the joint between panels in order for the door to flex backwards.
I could probably do that, but I found the easier option was to remove the roller at the joint between panels.
There is no noticeable weakness at this joint doe to the missing roller.My door 4.jpg My door 5.jpgMy door 6.jpgMy door 3.jpg
