- Nov 29, 2014
- 65
- 24,775
Re: MTD Yardman Transaxle Rebuild
Ooooh That was right out of the triangle.
We used to patch rusty iron roof with canvas & red lead , a paint submariners should be very familiar with.
However if you go that route the dope that canvas aeroplanes are painted with might be worth a look as it shrinks a lot when it dries in order to keep the skin on the plane tight.
I know you can get it in small tins because model aircraft makers use it on the paper skinned models.
Roger,
When you go to build your "boat" think foam insulation for your building material. Also a great sources of building foam is companies that sell small trailers as they use big blocks of foam to pad the trailers when they stack em up. You can use canned spray foam to glue the blocks together and then cut it with an electric craving knife, hot wire, hand saw or what ever floats your boat so to speak. Then use rasps,files, sand paper and or cheese graters to smooth it out. You can use "poor man's fiberglass" over it. That is old bed sheets glued on with Glidden paint's Gripper latex primer. Then you HAVE to paint it YELLOW. The parents will get it but I bet most of the under 30 crowd will not.
Good luck and post pictures.
Tom
