That's pretty sweet. I have done ditches way steeper that 30 degrees. Hill too. " point down go down "
Sorry but I am skeptical. I like your enthusiasm but lets lay off the koolaid a bit :confused2:. The 997 is a great unit, but I don't think you understand what a 30 degree slope is. 30 degrees with a 997? Maybe up and down with some good bar tires, but you will be turfing and rutting even with turf in pristine condition, my friends was turfing bad at 20 degrees and he was scared to death about rolling.
From the manual for the 997: "Never mow or operate machine on slope angles greater than 10˚. "
Not saying that it can't operate on higher than 10 degrees, 10 degrees is not much at all, just pointing out John Deere's spec and recommendation. Obviously you can do whatever you want :biggrin:
FYI The Yanmar engine is rated @ 30 degrees for 3 minutes, then it has to come off the slope.
